跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 个问题 查看全部
Blacklight, temperature, lcd, screen,
Hi guys
I have a problem with my iMac i7 27" late 2009.
sometimes the screen goes black for no reason. I try to put the flash from my iPhone on the corner of the screen and I can see the icons. Every time that I turn on my iMac after few minutes the screen goes black again. I leave the iMac until stand by and I come back to it after 10 minutes, the screen work again but after few minutes black again. I was thinking there are some problems with temperature sensor or my back light led doesn't work properly. I will insert few pictures from temperature gauge if you would to have a look.
Those picture are about 10 minutes working.
After those one just for the LCD temperature it's grow up in about 10 minutes.
Please let me know and help me to fix this problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
When it goes dark can you see the desktop with a flashlight?
完成的
Yes I can see the desktop with a flashlight. Not really well but I can.
完成的
Hello Claudio Pili, I have the same problem, What do you do to fix the iMac? Please Healp me. Thanks.
完成的
添加一条评论
1个答案
已选择的解决方案
Replace the LED Driver board. Here's how: iMac Intel 27" EMC 2390 LED Driver Board Replacement
It replaced the inverter but does the same thing.
这个答案有帮助吗?
得分 1
1条评论:
ok, I will try to replace the LED driver board. I will come back to let you know.
thanks a lot for the moment. :)
完成的
添加一条评论
添加你的答案
Claudio Pili 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 317
