跳转到主内容
The first-generation Ford Focus was manufactured in Europe from 1998-2004 and in North American from 1999 to 2007.
33 个问题 查看全部
2004 Ford Focus Radio problems...
Hello...I was driving down the road with radio on in my 2004 Ford Focus and it just stopped working. The clock (which is part of the radio) still works but can't get radio to work anymore. Could this most likely be a fuse? Is the fuse for the radio under the dash? Which one is the right fuse?
Thank you so much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
i have 02 ford focus and the radio,clock and cd player are all functioning but i get no sound. all fuses are good, aerial ant. is good i am puzzled. can anyone help??
完成的
my radio will not turn off when I turn car off
完成的
添加一条评论
3个答案
最有帮助的答案
Could be a fuse. There are two fuses for the radio. One for ignition off draw, and another for ignition on. There's a fuse panel in the knee panel below and to the left of the steering column. The fuse listing is on the inside surface of the cover panel, which is simply snapped in place.
这个答案有帮助吗?
得分 1
添加一条评论
I have a ford 6000 radio in my focus. Every once in a (sometimes long) while it stops functioning. When i take out the panel with preselect buttons 2 to 5, wait a few seconds and put it back in again, a miracle happens and it's working again....
这个答案有帮助吗?
得分 0
添加一条评论
If any of you guys have kids there is a good chance that something was inserted into the radio that doesn't belong. Also just like a laptop or keyboard the keys get sticky the same thing happens to the radio lots of dust and grime accumulate once every 2-3 months take it out and clean it
这个答案有帮助吗?
得分 0
1条评论:
My 2004 focus radio stopped working, but the clock kept working and after disconnecting and reconnecting the battery, nothing works. Fuse is fine. The instrument panel lights work intermittently, so I'm thinking there's a short. How do I check it?
完成的
添加一条评论
添加你的答案
Kathy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 45
总计 7,603
