跳转到主内容
Repair guides for the Samsung Galaxy Tab A series of tablets. Released in 2015.
470 个问题 查看全部
I can not get my earphones to work! ( Galaxy Tab A)
So I can not get my earphones to work, I can't figure it out or I'm just that stupid. LOL And yes they were plugged in , LOL And the earphones work worked great with my other tablet.
So if you might be able to help, that would be great.
Thank You, Terry T.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I try to put a headphone jack in my samsung galaxy tab a but it won't work
完成的
I tried everything and my headphones won't work but they work in my phone
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
First, do the tab's speakers work when you do not have the earphones plugged in? If not check the sound settings.
I know you said earphones work in another device. Just to prove things try a different set of earphones in your tab. If they don't work then your earphone socket is either faulty or has become disconnected off the board.
You could try just very gently moving the plug side to side or up and down while it is in the socket and see if you get any sound. If so it possibly proves a loose connection.
这个答案有帮助吗?
得分 3
3条评论:
Thank you so much! OK now have you ever sent any to be fixed? I have a problem with not being able to take it back a getting another one. I hate buying something just to find out that something not right and the inconvenience.
Jayeff ,
Thank you! I will try it again after feeding the animals
WISH ME LUCK, LOL
完成的
Hi Terry,
Under Settings > Accessibility > Hearing there are two setting you may wish to check.
Left/right sound balance: Set the device to adjust the sound balance when using a headset.
– Mono audio: Set the device to switch the sound output from stereo to mono when a headset is connected. Here is a link to the user guide scroll to p.95 http://downloadcenter.samsung.com/conten...
完成的
TRY USING USB TYPE C PLUG TO 3.5mm EAR PHONE ADAPTER (£4) IN THE CHARGING PORT OF THE TABLET. IT WORKS FOR ME, ACCEPT THE SELF CONFIGURATION PROMPT WHEN FIRST USING IT.
Keith
完成的
添加一条评论
添加你的答案
Terry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 48
总计 2,720
