跳转到主内容
Nintendo handheld device released February 2011, identified by model number CTR-001.
342 个问题 查看全部
Is it possible to fix a 3DS if the battery exploded?
I had my 3DS for two years now, then suddenly the back started bulging and when I opened it up, the battery exploded! I took out the battery a week later and decided to buy a new one, but before I bought it, I feel like it did some huge damage on the inside of the 3DS, and I'm worried it won't work anymore, is there a solution to this at all?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
SeamusGold64 depends what it all looks like. Post some images of your damage with your question. Use this guide 在已经存在的问题里加入图片 for that
Thanks for the answers, I bought my battery, found no acid since the battery didn't have any type of damage ( except for getting bigger ) and it works perfectly now. :)
Did the battery look rounded? I have the same problem, but I'm just trying to figure out if the battery is made like this, or if I need to get a new battery.
添加一条评论
2个回答
已选择的解决方案
The problem would be if acid got in there and damaged electronics. If you don't have another battery available to try or you're worried there might be long-term damage you'll have to disassemble the 3DS and inspect the components for signs of acid damage - discolouration of the board or circuit tracks/landings, white "fuzz" on aluminum, or solder joints that have separated.
这个答案有帮助吗?
按维修分数 0
评论:
Lithium reacts intensely with water, forming lithium hydroxide and highly flammable hydrogen. The colourless solution is highly alkalic Highly corrosive? yes. Acidic? no.
Read more: http://www.lenntech.com/periodic/water/l...
添加一条评论
It is a Possibility, you might have to get it refurbish,ed which would be really uncommon, for a battery to explode, but until, keep your hopes up.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
SeamusGold64 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 23
总计 1,371
