跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4099 个问题 查看全部
Screen touch doesn't feel right - everything looks fine.
Recently I have stumbled across an iPhone 5s which I cannot seem to fix. When I fit a new screen the touches don't feel right. The screen displays fine and the touch works everywhere, however you need to swipe with a big surface area, such as your thumb. If I use my index finger the screen won't respond, when I tap an icon it works, if I try to swipe around the settings/springboard it doesn't. If I keep my index finger on the screen for a while then swipe it works fine.
I tried 2 new screens, and 2 broken LCDs. Both of the broken ones where fine.
I'm guessing the 2 new screens come from the same batch and are both faulty?
The problem just seems so odd.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
Yes, they're faulty. Faulty OCA will cause this. Buy from a different supplier.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Giovanni Joubert 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 45
