romegio, start by checking what Apple suggest for those errors."When connecting the Mac Pro to AC power, verify that the LEDs for OVTMP CPUA and OVTMP CPUB briefly flash red (less than 0.5 sec). The LEDs are located under hard drive bay 1 on the backplane board. If they do not illuminate briefly, there is an issue with either the power supply or the backplane board. Generally speaking, power supplies, because of their nature, can be affected by issues more than other modules. If you suspect a power supply has failed,verify it in another Mac Pro (Early 2009), if available, before replacing any modules.
Note: The OVTMP CPUA and OVTMP CPUB LEDs on a properly functioning Mac Pro will also momentarily flash red immediately after the Mac Pro is disconnected from AC power."
Intermittent Shutdown
• Computer intermittently shuts down, restarts, sleeps
• Fans run fast
• Slow computer performance prior to intermittent shutdown, restart, sleep
1. Verify shutdown/restart/sleep issue does not occur with a known good AC Mains power source. Rule out customer environment such as defective uninterruptable power supplies. Rule out power generators which may produce noisy power, straining the computer’s internal power supply and causing issues.
Yes
Suspect unstable AC Mains power source. Using an alternate AC Mains power source resolves issue.
No
Go to step 2
2. Remove all non critical internal and external peripherals, i.e. AirPort, Bluetooth, PCIe cards, external USB drives etc. Verify shutdown/restart/sleep issue does not occur Yes Shutdown/restart/sleep issue does not occur when internal and external peripherals removed. Troubleshoot suspect peripherals.
No
Go to step 3
3. Verify if fans are running fast.
Yes
Go to “Fast/Failed Fans” Flow
No
Fans running at normal speed.
Go to step 4.
4. Reset SMC and verify computer functions correctly and does not intermittently shutdown/ restart/sleep.
Yes
Corrupt SMC State causing power stability issues. Resetting SMC has resolved the issue.
No
Go to step 5
5. Attempt to boot from original or compatible install media, or from a known good external hard drive with compatible OS X installed. Verify computer stays ON without any intermittent shutdown/restart/sleep.
Yes
Computer power remains stable and does not intermittently shutdown/restart/sleep. Clean install customer HD with compatible OS. Perform all Software Updates if required.
No
Go to step 5
6. Disconnect all internal boot volumes. The computer should not discover any boot volumes, and start to flashing Folder? Verify if the computer continues to intermittently shutdown/restart/sleep
Yes
Computer continues to shutdown/restart/sleep. Refer to Minimum Configuration Testing troubleshooting: Remove all modules and peripherals not critical to operation. Verify computer functions correctly and does not shutdown/reset/sleep unexpectedly. Then reinstall modules one at a time and restest until symptom returns. Verify if the last module added is not the cause by removing again.
No
Run Apple Service Diagnostic from an external USB drive. Suggest to also go to Minimum Configuration"
Let us know what you find.
