跳转到主内容
HP Elitebook 6930p announced in September 2008 and was one of the first generation EliteBook laptops. It was advertised as the first laptop to break the 24 hour battery life barrier.
18 个问题 查看全部
Will replacing the hard drive reset all my passwords?
I upgraded my operating system to windows 10 and have some how locked myself out of my computer, can i replace the hard drive to reset them?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
4条评论
You need to be more specific as to WHICH passwords you forgot. The OS or the BIOS?
完成的
I installed windows 10 off of an email offer I received, not off of a disk, so I don't have a disk. Can I make a copy of the disk off of my other computer that I also upgraded to use? Or do I need to go buy windows 10?
完成的
And I think it's the bios from what I'm reading online about it.
完成的
Then no - replacing the HD will not reset your Windows password. How did you lock yourself out of your laptop with a BIOS password by simply upgrading your OS? Setting a BIOS passwords involves you having to go into your BIOS and setting it up.
Tell me what you see on the screen when you power-up. Take note of everything you see on the screen like BIOS version.
完成的
添加一条评论
2个答案
最有帮助的答案
Which, passwords are you referring to -- the Windows OS passwords or the BIOS passwords.
IF it is the BIOS passwords, then NO -- replacing the HD will NOT remove that password. You may need to contact HP and prove ownership for them to reset that password.
这个答案有帮助吗?
得分 2
添加一条评论
well you dont want to change the hard drive an easy solution would be to reinstall windows10 that way you can make up new password.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
knottymama 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 92
