跳转到主内容
PlayStation Vita(PSV)是PSP的后续机型。PSV具有更加强大的处理器与画面,添加了第二个类比摇杆。PSV发售于2012年2月15日。
163 个问题 查看全部
It won't turn on and I've tried everything.
Whenever I plug my PS Vita into an outlet with the normal cord it does nothing, but when I plug it into a computer the PS button stays black until I try and power it on. That's when it blinks orange once for about a second. I've looked around for a fix but have never gotten one. It would be great if somebody could help.
Another bit of info: I left the thing to charge all night (7 hours) with the same results as previously stated.
The system has been dead for 5-8 months with no sign of powering on.
The only game used in the system is Little Deviants. (Not a very good game)
There has been no damage to the system. (Falling, water, heat, freezing, ect...)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I need help. my ps vita has been dead for 2 years and I have been charging it for awhile now and it has not blinked orange yet or even done anything. To check, I turn on the power button on for five seconds and it still did nothing. I have the proper charger
完成的
添加一条评论
2个答案
最有帮助的答案
confusing one....
i would say that the charger is dead and you can't charge it trought USB
can you test somehow your charger? or maybe lend working-one-for-sure?
if it's dead for 5 months then you need to charge it for at least 20min to power it up
i preffer to try to charge it with working charger overnight
if still nothing
take it appart (check for junk or blown stuff while you'r inside) remove the battery and meassure it it should be >3.2v<4.2v
if not the battery may be dead
if it's <3.2v it may be dead or discharged compleatly
it's common that the Li-Ion 's die when have charge under 3v for long time
maybe try to replace the battery from friend's ps vita?
then try to power it up,if it does your charger, charging port, battery or smth like that is broken
let me know after your research...
这个答案有帮助吗?
得分 2
6条评论:
The charger is dead from what I can tell and the battery may be the problem. The thing is, that I did use my working charger overnight (the computer) but it is still not powering on. The only thing is if the battery were dead wouldn't the orange light not come on when I press and hold the power button?
完成的
Also none of my friends have a PS vita so i couldn't check that solution.
完成的
Also thanks for responding so quickly, I thought it would take a week minimum to get any sort of answer.
完成的
you know it's luck how i respond, i have my own life and i don't sit 24/7 on my bloody laptop (can't buy myself an pc (too expencive)
"i would say that the charger is dead and you can't charge it trought USB"
"The thing is, that I did use my working charger overnight (the computer)"
please read and make my life easier....
PC = USB
try to get hand on other charger (i would say it can fix it but there is no "for sure")
完成的
Sorry for offending you and thanks for the help.
完成的
显示更多的1条评论
添加一条评论
I’ve basically got the same problem but once it’s fully charged I try to turn it on and the battery is dead again
这个答案有帮助吗?
得分 1
1条评论:
Never mind I just got it to turn on again. Finally. It’s been a whole year that it wouldn’t turn on for
完成的
添加一条评论
添加你的答案
Devon Housley 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 84
总计 6,667
