跳转到主内容
加入维修社区 - 创建账户
由 Trio Tablets 制造的 Trio Stealth-10 MST 10-21 是 Trio 平板电脑系列中名副其实的“工作马”,它为用户带来了更大的显示屏和更快的处理速度。
Why is my device constantly power cycling?
The device will charge fully and drain to 50% than die almost instantly...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Most likely this is an issue with the connection of the battery. Try disconnecting the battery internally and then reconnecting it.
这个答案有帮助吗?
得分 0
1条评论:
how do I open my tablet
由完成的 分享
添加一条评论
@cabrich1957 Assuming we're still talking about a The Trio Stealth-10 tablet, there's a battery replacement guide available here on iFixit.
Trio Stealth-10 Battery Replacement - iFixit Repair Guide
Unfortunately, Ian Russell's solution isn't a great one, as the battery doesn't use a connector that can be unplugged; instead the battery is soldered directly to the motherboard. So you'd need to use a soldering iron to disconnect the battery and reconnect it.
If you're experiencing the same issue as the original poster, I would disagree; this sounds very much like a battery that has reached the end of its useful life and needs to be replaced. That would be the first thing I'd try in order to fix the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ian Russell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 631
