broken inside screen need help
The inside of my screen has cracked and now all I see is crazy colors how do I fix it
Sounds like you need a digitizer and an LCD .You should go to wherever you bought the phone to see if you can get parts through them as this is not a common phone and aftermarket parts are not readily available.
这个答案有帮助吗?
I think you are out of luck, I had a look around and couldn't find any parts for this phone, you will need to replace the lcd/digitiser to get this phone to work again if you can find it. Good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 53
