跳转到主内容
The Syma X5C is a four-channel quadcopter with a built-in camera.
30 个问题 查看全部
How do I fix my Drone that won't lift off?
I just got my Drone a couple days ago and I have been busy so I could not take it outside to see how it works but today I finally got the time to take it out for a test drive but I let my sister try flying it and she allowed it to slam onto the ground from a high altitude and now the propellers are spinning but its not taking off. How do I go about fixing it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 63
68条评论
Ok unlike all of the other answers I have the correct way to fix this although it will not be easy. The reason your drone will not take off is the motor broke or went bad when it hit the tree. Some people have the problem where there drone will not take off and it leans left or right I had this problem. That has NOTHING to do with it, the way you can fix this is by ordering a new motor and watch this video https://youtu.be/tpEhf7I6R9s
Hope this helped !
完成的
Btw you can fix your drone from leaning left and right by tuning it with these three buttons 1.The button under left stick 2.The button under the right stick 3.the button to the right of the right stick if you have any problems email me at charlieramont67@gmail.com
完成的
I just got my drone yesterday. I turned off the trim but it still zooms at an angle backwards and it wont go off the ground.
完成的
All I have hit though is the wall with the rotor guards on and it still looks like it was just bought from the store. I don't think the engine broke.
完成的
how can we stop all moters of quadcopter with radio transmitter wihout using autopilot? .and also we want to know about to control moters in same speed.
完成的
显示更多的63条评论
添加一条评论
12个答案
已选择的解决方案
Check all the props for damage and debris around the shafts(string and things like that). Other than that make sure you have a fully charged battery
这个答案有帮助吗?
得分 21
32条评论:
I have fully charged the battery and it still isn't working. I am going to check the shafts for debris later today and I hope that fixes the problem.
完成的
My drone just will turn into when it's off
Pls HELP
完成的
This is a brand new expensive drone so please please please please please help me plus only one day of flying made this happen
完成的
What does it not turn into when it is off? That question makes no sense! Is it supposed to turn into a pumpkin or something?
完成的
My drone is a D X 3 and i got it a day ago and now it wont light up even though I charged it for a couple of hours.
完成的
显示更多的27条评论
添加一条评论
I had the same problem after switching my propellers out, my drone (X5SW) didn't want to lift and kept tilting to the right. After some searching I found that if you don't have the propellers in the right sequence, that you're not going anywhere. I switched the props to the picture on the box and low and behold, I'm flying again!
这个答案有帮助吗?
得分 16
9条评论:
I had a problem. my all props are placedright but it is still going in on side
完成的
gorav malhotra did you get it fixed?
完成的
I see new props have the A-D markings on them but can't find letters on Dronium 3 arms. Wont get off ground and revs up motor very strong. No support for this either on their site. What else to be expected.
完成的
I switched the props but it's still not flying and turning to the right side
完成的
lay one of your props on your table in front of you, just simply set it there by itself longways not sideways the front half of the prop should be angled down to the left the bottom half to the right.... this is an "A" blade.........the rest shuold be easy
完成的
显示更多的4条评论
添加一条评论
On a lot of these toy grade drones if you get hung in a tree and the transmitter is still throttle up you are going to burn out something. I had issues when I was new to the hobby, so I feel your pain.
这个答案有帮助吗?
得分 6
2条评论:
I was trying to fly a friend of mine's just to see how to fly it it flipped over when I try to take off and now one rotor will not turn what can I do
完成的
Mine did that and I had a bent shaft on motor. The next time it happened the plastic gear was wore. Both times I had to replace motor...
完成的
添加一条评论
If the motors are spinning up, it is likely an issue with the flight controller or ESC's. Have you tried calibrating the gyros? Turn the copter on and place on the level surface, I believe it is both sticks down and to the right (might be left, varies from manufacturer), hold and watch the LED's on the bottom flash, once the flashing stops it should be calibrated. I have seen that happen before after taking a crash. If the gyros don't agree with each other it won't fly.
Do the motors actually respond to the throttle up to point? Meaning you can spin them up and down a little bit just not enough to take off? Or is it just spinning in Idle when you turn it on?
Also, I'm not sure if it was a question or just a comment, but you should always have 2 motors spinning clockwise, and 2 counter clockwise.
这个答案有帮助吗?
得分 5
7条评论:
It still doesn't work and just when I turn it on
完成的
my dronium one want lift.... slide to the right in a circle
完成的
I have one motor that doesn't work until you turn the model upside down. Any ideas?
完成的
I press throtle trim button on my hexacopter remote, after that 4 motors are spinning up and other two spining down and it won't take off when I speed up it starts jumping from front but other propellers are moving in opposite direction and they pushing air to the top not to the ground
完成的
I have four rotor blades off three of them work one does not turn on at all so it's not responding to the motor to the joystick I don't know what to do I guess try and take it apart throw that hundred something dollars away
完成的
显示更多的2条评论
添加一条评论
recalibrating the gyros WORKS follow the directions
这个答案有帮助吗?
得分 5
1条评论:
How do u recalibrate the gyros?
完成的
添加一条评论
Props are marked A and B. Make sure they're mounted on the correctly marked arm of the quad. Recalibrate the transmitter
这个答案有帮助吗?
得分 3
2条评论:
i put on 2 new propeller my dronium one arm are not mark a&b, so where do i place (a) left or right front
完成的
Cant find A or B on drone arms just marked on new blades I put on Dronium 3 and now wont fly off ground. Revs up very goo tho...lol Lack of company support :(
完成的
添加一条评论
You need to reset your drone by moving the joysticks to the bottom right and when you open your remote push the botton that is under the right joysticks you only need to do this once
这个答案有帮助吗?
得分 2
添加一条评论
Motors cost nothing a few pounds for a set of 4 . If u crashed it u more than likely damaged the motors or control board. Check all the solder points are ok and no wires are detached. If thats ok and the motors rev up and respond to transmitter power then the board is naf. U can bypass the power control by placing a small blob of solder on the board in the right place. This bypasses the gyros and enables normal flight again. The gyros perm set at default so no need for calibration. Email me if u want to know where and ill send u photos stormx29@googlemail.com
这个答案有帮助吗?
得分 0
2条评论:
If you don't ever have to recalibrate the gyros then why do most instruction manuals show you how. Is this just something to do that has no effect? Maybe they tell you that just for poops and giggles. Give me a break.
完成的
Hi can you email me the pictures of where to put the blob of solder at home I drone my email is JJcool16758 @ gmail.com
完成的
添加一条评论
switching the props around worked for me. The quad now takes off and fly's correctly.
这个答案有帮助吗?
得分 0
添加一条评论
I have FOUND the answer to your problems (1) You might have the propellers in the wrong spots! I lost my drone for a week then someone found it and the wings were TERRIBLE and so I cleaned them. I put them back on and turned the drone on and it wouldn’t fly. You have to check the propellers to see which number it has on it.
这个答案有帮助吗?
得分 0
添加一条评论
Quad Props set up:
A B
B A
这个答案有帮助吗?
得分 0
添加一条评论
Hold the drone from the bottom and lean it every direction, you will find the weak motor. If one motor is weak it will pitch to one side and only hover as high as the weakest motor will let it. Drones fight to stay level, so by tilting the running drone from rotor to rotor, you can tell if one is fighting back less than others. Replace that one.
这个答案有帮助吗?
得分 0
1条评论:
My drone turns on the 3 seconds beeps once and does nothing after that.Why?
完成的
添加一条评论
添加你的答案
Matthew Winner 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 60
过去 30 天: 257
总计 328,780
