跳转到主内容
任天堂 Game Boy的彩色版本,发布于1998年。 维修Game Boy Color十分容易。
29 个问题 查看全部
What are specific steps to repair the speaker
I bought a speaker and special screwdriver and need to know what the specific steps for speaker repair are
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Apple Watch 套装
Screen and battery repairs just got easier.
现在开始购物
Apple Watch 套装
现在开始购物
1个答案
已选择的解决方案
Hi,
Here is a link from the Ifixit website which shows you how to dis-assemble (teardown) your Game Boy Colour.
Game Boy Color Teardown
At Step 4 in the teardown, you do not have to drill out the screws, apparently, (take note of the comment at the bottom of the page).
At step 6 in the teardown instructions you can already access the speaker so that you do not have to dis-assemble any further (Step 16 in the teardown link below shows what the speaker looks like).You will need to unsolder the wires from the old speaker (do it at the speaker end not at the circuit board) and solder them on to the replacement speaker. Carefully remove the speaker from its' mount before you unsolder the wires. It will be easier to manage. Also solder on the wires to the new speaker before you remount the speaker.Take note of how the old speaker is placed before you remove it. Install the new speaker the same way. Take a photo if you think that it will help to remind you.
Notes
Keep a container handy to place the screws in as you remove them. Also any other parts that are either removed during dis-assembly or that accidentally come off during the process. You'll be surprised how they can disappear!
I cannot see in the photos in the teardown how the speaker is mounted so you may have to work out how to remove the old speaker. As with everything in electronics, be gentle, most larger components are either held by a screw or a clip of some description. If it is a plastic clip be very careful as you do not want to break it if possible. If it is and you do accidentally break it, you may be able to hold the new speaker in place with a dob of silicon sealer where the clip was - superglue, I've found reacts with a lot of plastics.
Re- assembly should just be a reversal of the dis-assembly procedure.
这个答案有帮助吗?
按维修分数 2
评论:
Thank you so much. This was very specific and I can't wait to try it later this week!
添加一条评论
添加你的答案
smarshall561 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 230
