跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
I do I need to replace my phone's LCD?
Hi all,
My phone screen randomly started doing this the other day (although it had been dropped a few hours before that). As you can see, half the screen has a grey tint, and sort of artifacts begin developing after 30 secs.
My question is this: do I need to buy a new lcd, or is it worth cleaning and reseating the cables for my current one?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Since you did say it was dropped before your screen started to act up i would say that now your screen is on its way out. Which means that pretty soon it will eventually black out or wont work at all so yes you should get your screen fixed as soon as you can
这个答案有帮助吗?
得分 0
添加一条评论
If you open that and reconnect the connected. It may be fine.
Worth to try
Luck
这个答案有帮助吗?
得分 0
添加一条评论
Hey everyone, just an update here:
It started to gradually worse, as Justis warned, so I ordered a new lcd and that's solved the problem. The old lcd had a big bend in it under the grey part, so I guess that's what caused the damage. For anyone else with a similar problem, you have a warped lcd which will have to be replaced!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 69
