跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Battery does not charge after change
Hi,
i replaced the battery of my iphone 4s. no problem during the replacement process.
After plugging it in again its only showing the battery with 3 small stripes. There is no charging process or other icons like the lightning.
Can someone help me please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
David, of course you want to double check your work first. After that replace the new battery and see if the old will charge. It is possible that you have a bad battery. The standard way to check will be trying to charge with a different charger (use a wall charger not your computer to ensure a higher amperage) and make sure that you have a known-good cable. Check the dock connector for any broken bend or corroded pins. Clean it with some isopropyl alcohol and a few puffs of compressed air. If all that should fail, you will have to check the charging circuitry on the board. There is always a possibility of pry damage to some small component.
这个答案有帮助吗?
得分 1
1条评论:
the bad thing is that i damaged the original battery... so i can not test it..
i also tried several chargers. before the change everything worked well.
I hope its only the battery so I ordered another one and i will try in on monday ..
thank you for your help!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 97
