跳转到主内容
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
34 个问题 查看全部
PSP LCD replacement, do all the 300x series have the same LCD?
Hi,
Can't seem to find info on this online, does anyone know if the PSP 3008 screen is the same as the 3000, 3001, 3003, 3004?
Found a replacement for those models locally but not sure if it fits the 3008 (I believe this was a russian model)
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
How about psp 3000 version? The other psp 300x lcd also compatible?
完成的
添加一条评论
4个答案
已选择的解决方案
For anyone else looking for this answer, yes the 300x series are interchangeable. Ordered one that stated it was only suitable for the 3001,3003,3004 and worked flawlessly in the 3008 model.
这个答案有帮助吗?
得分 0
添加一条评论
does it work for the 3006?
Unique Usernam
这个答案有帮助吗?
得分 0
添加一条评论
I had bricked psp 3004. I bought a motherboard. It is ta 090. I changed motherboard. It was ta 094. After i power it up with new ta090 i have bad screen. https://ibb.co/eVten7 any ideas?
这个答案有帮助吗?
得分 0
添加一条评论
Tuna, I think you might have bent the cables coming out of the LCD screen. This is what has happened to my current PSP 3003 screen, when I was replacing the D-pad sensor; I must have accidentally mishandled the wiring, and now the screen looks exactly like yours. The only option you have is to replace the screen wholly with a new one, see ebay for cheaper alternatives.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brendan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 1,727
