苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3787 个问题 查看全部
Touch screen is crazy! Help!
My iphone 5s touch screen is somewhat crazy it just opens apps and get down and up simultaniusly but if i twist the phone it goes normal. What can be that?? A faulty screen digitizer or the touch ic on the logic board?? Any help would be great
Thanks in advance
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
It's your display assembly. For whatever reason, it's gone faulty. If you're feeling gutsy. Here's labor
iPhone 5s 显示屏组件更换
Here's parts
iPhone 5s LCD and Digitizer
iPhone 5s LCD and Digitizer张图片
产品
$39.99
这个答案有帮助吗?
按维修分数 1
评论:
I already changed the digitizer and still the same. When it doesnt work i twist the phone and it works again. I double checked connections and all are good and clean
Twist the phone? Now it's starting to sound like the touch IC
Yup thats the problem
添加一条评论
There is a couple things it could be a faulty digitiser or a loose connector
这个答案有帮助吗?
按维修分数 0
评论:
I already changed the digitizer and still the same. When it doesnt work i twist the phone and it works again. I double checked connections and all are good and clean.
添加一条评论
I am in the same boat, replaced the whole front digitizer assembly and phantom touches still are present. actually lost some functions with this as well.
这个答案有帮助吗?
按维修分数 0
评论:
*****Update***** after replacing my digitizer and the problem still persisted, it came down to the logic board. Buying the logic board was more than buying a used phone. I found a friend and bought his old phone instead.
添加一条评论
Ok i took apart my phone and search on google about the problem and i found that for some reason the touch ic its not doing enough contact to the board. So cause i dont have any heat gun or tool to get to it i just mark the steel on top of it so it does a little pressure on the ic and now the touch is working. I will try later to get the metal top out and heat the ic to see if that resolve the problem for all cause im still getting some points with no touch.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
jel2005 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 190
