跳转到主内容
加入维修社区 - 创建账户
于 2013 年 5 月发布。显示屏 - 1200 x 1920 像素,10.1 英寸。芯片组 - Qualcomm Snapdragon APQ8064, CPU - 四核 1.5 GHz Krait,GPU - Adreno 320。存储 - 16/32 GB,2 GB 运行内存。运行 Android 操作系统,v4.1.2 (Jelly Bean),可升级至 v4.4.2 (KitKat)。
black screen and red led blinking 3 times
the lcd was broken after a drop. tried replacing the lcd assembly but now the tablet won't turn on. even with the old screen i can't seem to get it booted. tried al the button combinations but it didn't work. tried unplugging the battery for 10 min. still nothing. when i press the power button the led flashes 3 times, that's it...
any idea's ???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
when you replaced the screen did you disconnect the power before working on the tablet or was the battery connected during the replacement?
完成的
yes, I disconnected the battery before working on it...
完成的
Just a question do You know there's a shift button for a reason Ibar
完成的
Cody, I'm here to help people with their electronics. My first language is dutch, second is french. So please excuse me for my english and if sometimes I forget to write I with a capital I...
greetings iBar
b.t.w. Do you know there are buttons for punctuation? ;-p
完成的
Yes I do I am sorry.
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
iBar, this can be caused by a bad/drained battery. Make sure that you charge your Sony with a known-good charger/cable.
这个答案有帮助吗?
得分 2
2条评论:
all i needed was the original charger :-)
完成的
添加一条评论
添加你的答案
ifixshop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 30
总计 20,669
