跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2932 个问题 查看全部
Can I replace a glass + digitizer only?
Hello members,
Just to be sure ill start with the following terms:
Glass = glass
Digitizer = touch
LCD = display
I got a new iphone 4s glass+digitizer+lcd assembly and I accidently ribbed this cable: it is the touchscreen ribbon. Is this fixable?:
because ebay sells: http://www.ebay.com/itm/Touch-Screen-Dig...
I know I can just better buy a whole new assembly, but im just wondering if touchscreen is fixable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
评论:
If the cable is ripped replace the works the odds of repairing this are near imposibble
完成的
添加一条评论
2个回答
已选择的解决方案
Yes but I wouldn't, a lot of work is involved to change just the glass/digitiser and generally the LCD ends up breaking anyway so to save time and grey hairs i'd just get another assembly.
这个答案有帮助吗?
得分 4
添加一条评论
Looks like you need to replace it all LCD and digitizer
这个答案有帮助吗?
得分 2
评论:
Why are you just repeating what has already been posted?
完成的
添加一条评论
添加你的答案
Job Wintjes 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 438
