Why are the pictures I take blurry?
The pictures I take with my cameras on my Lenovo A8 are coming out blurry? Why?
It is possible that the protective coating from the factory is still present on the lens, or the lens is simply dirty. First, try cleaning the lens with a clean cloth, dampened slightly with water or rubbing alcohol. If that doesn't work, the camera may be unable to focus properly, or is otherwise damaged. Also, note that the front-facing camera has much lower resolution compared to the rear-facing camera (2 megapixels versus 5 megapixels).
If you decide to try replacing either camera, there are iFixit replacement guides available here:
Rear-Facing Camera Replacement
Front-Facing Camera Replacement
It is a very easy fix, and replacement parts are readily available online. Good luck!
指南
难度:
简单
8 minutes
指南
难度:
简单
10 minutes
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 652
