跳转到主内容
由 Nokia 生产的 Windows Phone 手机修理指南。
513 个问题 查看全部
Do I need to buy digitizer or the LCD
Hi
My lumia 820 fell a couple of weeks ago and got its screen cracked. The strange thing is, the outside screen was fine, but a single crack happened in the inside. Now the display is not working. I opened the phone and noticed that the inside of the digitizer was broken. So i am a bit confused, is it because the digitizer was broken from the inside that the display is not working. Or is it the LCD (which doesn't happen to have any scratches on it).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The LCD display is more delicate than the digitizer is. I have seen broken LCDs with intact digitizers in iPads and iPhones from being dropped. My suggestion is to replace both the LCD display and the digitizer since you noticed that the digitizer was broken on the inside. Usually a digitizer can break and still partially function with the LCD still working properly. Also, a LCD display can seem unbroken even if it is. The only way to tell if it still works is to have it turn on.
这个答案有帮助吗?
得分 0
添加一条评论
Always buy the two parts together even if it looks okay cause if your phone isn't displaying anything, it means the LCD display broke. And naturally if you drop your phone the glass has to take damage and you'll have to buy a new glass anyways.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
neel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 56
