Is there a way to Bypass the system password
I'm locked out of my Toshiba Satellite c855d-s5307, my three year old daughter was playing with my puter and somehow changed my password and now I can't get in at all
This link might be helpful in resetting your password. I never used it myself, but I read that it's not bad.
这个答案有帮助吗?
This will work. You will need another computer that can burn a CD to burn a disc that you can use to reset your password. I have used this tool a couple of times. The process is a little more involved than just inserting a burned CD into your computer.
I searched around a little and came up with a few links. You can try these, though I have no experience with them myself.
http://www.pogostick.net/~pnh/ntpasswd/
这个答案有帮助吗?
You must burn a password reset CD similar to what was posted by Jesse.
Insert the Burned CD into your computer drive. Restart computer. Continuously tap the F12 key until you get to boot menu.
Pick the CD/DVD drive in the menu to boot from the CD. Let the CD disk startup and follow the directions to reset your password.
这个答案有帮助吗?
i had this same problem if you have nothing you want to save then do a reinstall of windows that way you can set up a new password.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,346
2条评论
I think you can get software to reset or recover your password. Let me check a bit more.
由 Jesse 完成的
Mike, will this be the password for your Computer (BIOS ) password, or the one to your Operating System (i.e. Windows? Which operating system are you using?
由 oldturkey03 完成的
