跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Front and rear camera, flashlight not working , help...
Hello everybody. This is my first question on this site, so please try to help me.
I have changed iphone 6 housing with new one, the MB was working 100% before the replacement, and now i have gut a problem with the rear and front camera and flash light they don't work!!!!
I have checked everything on MB, Camera's, flex cables, components,
I tried all kind of restores, even new framwear. It doesn't help
And also i put the MB on another 100% orginal and working phone, still the same ,
I am working with iPhones almost 3 years and i am professional but this is my first case whene I couldn't find a solution,
Does anyone know the solution of my problem????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
The storage isn't full is it? I know on the iPhone the camera will not work if the device has no space. I've seen in some cases where it will not tell you the storage is full when you go to the camera. Pretty lame but it might be worth a shot! As for the flashlight it might be a board issue if you have tried multiple flex cables.
这个答案有帮助吗?
得分 0
4条评论:
Hello Leevancleef, thank you for your answer .
My first setup was to do a factory reset so i had completely empty memory but it doesn't work.
I'm sure that i have hardware problem. Why ?? No idea yet
完成的
I totally missed that I am sorry! I know on the 6 some water cleanups we have had the camera never comes back on. t could be a component that was damaged (if not by liquid something else) Are you able to test with a different camera?
完成的
I am facing same problem. Actually my phone was !#^&@@ off by car. But everything is working fine except both cameras & flashlight. Is it MB problem or camera's problem? There is no crashes around front camera but housing around rear camera is totally messed. Is there any common components between rear cam, front cam & flashlight? Should I try on MB or cameras? Or if cameras then which camera I should replace?
完成的
I had to replace both my front and rear cameras recently (my phone was also run over), and when the rear (main) camera was bad, the flashlight wasn't working. When I replaced it with a new camera, the flash and flashlight worked. So they're connected.
完成的
添加一条评论
Here is guide for you. Hope it can help you:
How To Fix iPhone 6 Camera Not Work After Repairing
这个答案有帮助吗?
得分 0
1条评论:
That link seems to be broken.
完成的
添加一条评论
添加你的答案
Armen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,378
