跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
iPhone shuts down suddenly and stays black
Hi,
My iPhone 4s now several times suddenly shut down and stayed unresponsive for a long time (1h), at any battery stage.
  • I pressed the two buttons for 30sec many times...
  • it is not detected in iTunes
  • it doesnt display if the charger is plugged or not
  • it seems hot after the moment of shutting down.
What would I need to check / replace? I don't know where to start...
What I noticed recently is that the last 20% of battery some times discharge extremely fast. Might it be the battery?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
yes that sounds like a battery problem. just to be sure try a restore with iTunes an do not put you backup back on the device
这个答案有帮助吗?
得分 0
2条评论:
Thanks! Now, I have not been able to bring it back for 24h. I actually don't see it in iTunes at all. It seems down. ..
完成的
No, it is definitively not the battery. I have replaced it with a new one form iFixit, but still the black screen persists. I cannot see the iPhone from within iTunes.
完成的
添加一条评论
I would look into getting a new battery.
这个答案有帮助吗?
得分 0
2条评论:
Thanks! I probably will.
完成的
I have replaced the battery with a new one from iFixit, but still the black screen persists. I cannot see the iPhone from within iTunes.
完成的
添加一条评论
Does the wifi work? Coz some of the iphone 4s have problems with the wifi module , and that causes fast battery drain, and resets on the iphone 4s ??
这个答案有帮助吗?
得分 0
2条评论:
Thanks! Wifi works bot not exceptionally well (sometimes slow...). I had short blackouts several times, is it that?
完成的
No every thing is black... and down.
完成的
添加一条评论
Well, after I had replaced the battery and nothing had changed, I however noticed that the phone was heating up. So it meant that there was well some energy...
After some google I found this, where it says it could be a problem of the connections between display and unit.
Indeed, in the past, I had exchanged the display once and the backside twice... so I reopened everything and disassembled it agin and rebuilt it back...
=> and it worked!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 359
