跳转到主内容
Thin and more powerful than ultra-budget laptops.
20 个问题 查看全部
Why does my Laptop only work when the charger is plugged in?
My laptop only turns on when the charger is plugged in and even then it fails to charge. As soon as I remove the charger from my laptop, it completely shuts down and I have to once again turn it on by plugging in the charger, pressing the power button and continuing to keep it plugged in until I stop using it....
Why won't it charge at all, and yet why does it only turn on with the charger plugged in?
The green light on the charger lights up when the cord is plugged to the laptop, which means that charger is working. I think it may be the battery but ive tried to reset it and take it off the laptop and then put it back on several times but still the same result.
PLEASE HELP ME IF YOU CAN, I'D GREATLY APPRECIATE IT! Thanks :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
5个答案
已选择的解决方案
Replace the battery, they're cheap: http://www.amazon.com/s/?ie=UTF8&keyword...
这个答案有帮助吗?
得分 4
2条评论:
excuse me i have same problem but my battery is proper what might be the reason
完成的
Roshan, it would be best to start a new question so others will see it. I don't have an answer right off the bat.
完成的
添加一条评论
My new Lenovo did the same thing after having it for one month. Tech came and replaced the motherboard today. Still doing the same thing.
这个答案有帮助吗?
得分 0
添加一条评论
My laptop only works when it is plugged in, i bought a new battery and it still only works when plugged in.
And now their is a X on the battery icon. Can you Please help me and tell me why that is ..
Thanks in advance!
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem, it was fixed after I bought a new battery, it was saying before I booted it up that the batter wasn’t working properly anymore, so when I got a new batter the problem was solved. This happens because of 4 reasons
# Battery was physically damaged (like your computer fell or something)
# Battery has reached it’s full potential and the lithium-ion has died, so it can’t be charge anymore
# You keep your computer plugged in when it doesn’t need to be charged so the battery overheats and after too much over heating the battery basically dies.
# Your computer has been hacked or infected with a virus, and when the motherboard blocks connection with the battery it cannot receive power from it. I don’t know how hackers do it, but somehow they can block connection from your battery to the motherboard.
  1. The only other way you can get this fixed without replacing the batter is calling a technician and seeing what they think about the situation.
  2. Hope this helps. :)
这个答案有帮助吗?
得分 0
添加一条评论
I don’t know why but my laptop did the same thing. Then the hinges started breaking. We noticed that some screws on the bottom were missing. I replaced them and the hinges were back to normal. After than I checked on it and the laptop was working without being plugged in 24/7! I don’t know why it worked but it did. Check your laptop for missing screws!
这个答案有帮助吗?
得分 0
1条评论:
I'm having the same issues with my Acer laptop, which I did bought a new battery but it still not working without changing
完成的
添加一条评论
添加你的答案
AquaBlue 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 32,086
