跳转到主内容
Panasonic released the CF-29 on January 1, 2004. It was designed to survive the harshest environments US Armed Forces, service personnel, and enthusiasts could throw at it. The Black Hawk CF-29 was released in 2009.
17 个问题 查看全部
problem with can't power up panasonic toughbook cf-29
i can't power up after battery was charged.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Well, not in my case. Now what? Is it just a brick?
完成的
toughbook module cf-31, I pulled battery and tried turning on, but didn't come back on.
What next?
完成的
添加一条评论
1个答案
最有帮助的答案
On most toughbooks please follow these instructions in order:
Step 1: Please Un-Plug AC Adapter (External Power Supply).
Step 2: Please Remove Internal Toughbook Battery Pack
(In some cases, you must release the latch located on the underside of the Toughbook).
Step 3: Do not put back the internal battery but plug back in the AC Adapter.
Step 4: Turn on the power (ie. start-up the Toughbook with the power button).
(In most cases the Toughbook will turn back on without the internal battery pack).
Step 5: Once the Toughbook is powered back on, do a complete shutdown of Windows.
Step 6: Put back the internal battery pack.
That is it. Your Toughbook should now work as normal.
Good Luck and Regards from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
这个答案有帮助吗?
得分 4
10条评论:
Perfect! You fixed me, thank you.
完成的
it worked for me, you saved my 3 Panasonic CF 54. thanks.
完成的
Worked on Panasonic CF-AX2. thanks.
完成的
Try already. But Can not ON
完成的
Is toughbook On without battery??
完成的
显示更多的5条评论
添加一条评论
添加你的答案
drhaswell 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 60
过去 30 天: 212
总计 18,340
