跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
问题已关闭
iPad Air ran over by car, best way to replace screen?
Hi, I came across and iPad Air that appears to have been run over. It had a case on it but the digitizer and LCD are trashed. Logic board still seams to be intact cause the alarm clock on it woke me the next morning. Tried finding the owner for it but no luck. I'm wanting to fix it up for use again but I'm not sure what the best way is to remove all the glass and adhesive. Also I've been trying to find another iPad Air that has a logic board problem so I can just do a board swap seeing that most of the other components are damaged or missing. Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Before you start working on it make sure it is not iCloud locked or else your going to waste your time and money for nothing.
这个答案有帮助吗?
得分 0
1条评论:
I connected it up to my computer and it would only let me do a restore on it. Haven't done it yet though
完成的
添加一条评论
Check the serial number here to see if icloud lock before repairing it https://www.icloud.com/activationlock/
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 305
