跳转到主内容
修复你的物品
维修的权力
商店
Repair and disassembly guides for Magellan GPS devices.
73 个问题 查看全部
My gps lights up but does not show a map or talk
I don't use my gps often it just started to go bright, but no screen picture or choices just lights up.
What could this be. do I need to purchase a new one
mg
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
已选择的解决方案
Hi,
Have you tried to "reset" it?
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch
If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button
If your unit has a Push Down Power Button, look for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch
If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
milliemilford 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 101
