跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
724 个问题 查看全部
iPad 2 black screen
My iPad 2 screen went black... i see it's turn on... back light but no image. Hard reset won't do nothing. When i do a screen capture i momentarly see my screen a little...
I tried to to hit it a little like i saw in some messages but it's doing nothing. Any help please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Yeah, your backlights out. Not super big on iPads. But, I think you just need to replace the LCD.
iPad 2 Wi-Fi EMC 2415 Front Panel Replacement
iPad 2 LCD
iPad 2 LCD图片
产品
iPad 2 LCD
$59.99
这个答案有帮助吗?
得分 2
添加一条评论
It's likely that the iPad will need to have the lcd cable reconnected. Sometimes smacking the back doesn't work. With the proper instructions And patience you can open the iPad and do this. Be sure to power the iPad off first though. Just hold the power button for about 5-10 seconds then swipe not the screen towards the top where slide to turn off would be. You should see the backlight dim slightly then turn off.
Follow the ifixit guide to open an iPad 2, and you'll be good to go.
这个答案有帮助吗?
得分 2
添加一条评论
Didn't work, followed the procedure and did what was required with no changes. Still a dark screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
martinesabourin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 717
