跳转到主内容
Repair guides and support for LCD e-writer tablets manufactured by Boogie Board.
Boogie Board won't erase
I have an old Boogie Board. It is not a fancy one that you can plug into a computer. I bought it a couple of years ago. It was stored for about a year. Now the screen will not erase. Is there a way to repair it that doesn't cost more than the device?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 42
42条评论
Mine is not a year yet but my cousin play when I was out and now it's spoiled. I can't erase I changed the battery and it still can't erase
完成的
The info about clearing the "deep sleep mode " totally worked for me by pressing the erase button 10 times and I was floored that it cleared the screen.
完成的
Didn't work for me. Mine was only used a couple of times. It is 6 weeks old. Amazon won't exchange after 30 days!
完成的
I just sent an email. I will post my results.
Why doesn’t the LCD writing surface clear when I push the erase button?
If you are having problems erasing please contact support@kentdisplays.com for help.
完成的
I just heard from Boogie Board Mfgr.
They emailed me back within 24 hrs.
They want me to email them a response to a few basic quiestions... date of purchase, etc. And they will send me a replacement, right away~
完成的
显示更多的37条评论
添加一条评论
16个答案
已选择的解决方案
I found that it helps to pinch the lower right-hand corner of the device when pressing the button. It may even work a few times after that without the pinch, but if it doesn't then pinch again.
这个答案有帮助吗?
得分 62
68条评论:
This worked on ours. Model WT14029 from Costco.
完成的
Mine worked for 2 weeks and then wouldn't clear. Even the company's website said it's probably damaged due to water. I was about to throw it away and write a scathing review on Amazon. Then I saw this and it worked! Thank you!
完成的
omg just tried it and it worked thank you!!!
完成的
This worked great! Although it's unclear what you consider lower right hand corner. For me it was the upper left. So, I would try all 4 corners.
完成的
Worked, Thanks!
完成的
显示更多的63条评论
添加一条评论
Model wt14029 started to not erase also. Tried three different batteries but nothing worked. Finally found out after reading some of these reviews, we have to PINCH TOP LEFT corner while pushing the erase button. One of the previous posters was confused about which corner is which. I am considering the top left as the top left as you are viewing the board so you can read the words "boogie board" right side up.
这个答案有帮助吗?
得分 9
12条评论:
Mine had the same problem and this seemed to fix it .
Thanks
完成的
Upper left (button on top) !!!
...if you can't read the logo anymore ...
完成的
I had the same problem and this solution seemed to work. It happened again and now pinching the top left while pressing the button doesn't seem to work anymore. Please help
完成的
Can not get anything to work omg
完成的
Tried every corner top left worked :). Thanks
完成的
显示更多的7条评论
添加一条评论
The instructions say that it may go into a deep sleep mode and to get it out, you need to repeatedly press the button about 10 times. Hopefully that might help.
这个答案有帮助吗?
得分 7
14条评论:
This worked for me!! Thank you.
完成的
I had to repeatedly push a few more times than 10 but it eventually worked. I hope this isn't something that happens often but I'm not hopeful after reading these posts.
完成的
Didn't work for me. :(
完成的
I hope it works!!!
完成的
Worked the first time then stopped working!!
完成的
显示更多的9条评论
添加一条评论
Hold the left side of the button when u press it will go away the same thing happend to mine.
这个答案有帮助吗?
得分 3
11条评论:
I tried, but sadly, it doesn't work.
完成的
OMG... It worked!!
完成的
Well it sorta worked... It just faded.
完成的
It worked for me too. Thanks very much. I thought it had got spoilt. WT14029 is my bogie board model number. Pressed the top part of the beside the button. Thanks again.
完成的
Thanks everyone...I tried it, but 10x didn't do it, then I did it repeatedly, maybe up to 30x and it finally worked. It's my dad's, and he is deaf and 99...he'll be happy when he gets up in the AM to see it is working again, and we won't have to contact the company!
完成的
显示更多的6条评论
添加一条评论
pinching the lower right corner worked the first few times, but now it is no longer working on my sons boogie board. it doesn't have a locking switch, just a button.
这个答案有帮助吗?
得分 2
1条评论:
I need an answer fast! Should I contact the company to get me a new one
完成的
添加一条评论
I had the same problem so I emailed the company. They responded quickly and are sending out a replacement. All I had to do was provide the serial number, date and place of purchase, and my address.
Try contacting them. Excellent customer service from what I've experienced
这个答案有帮助吗?
得分 2
1条评论:
Do you have a phone number for Boogie board?
完成的
添加一条评论
Carefully remove the sticker "Boogie Board" on top of the screen to access the screws. Open the lid. Carefully remove the solded CR2025 battery and replace it with a new one. Protect it from short-cut and fix it with cellular tape. Close the lid and fix the screws. Reattach the label sticker (if you like).
这个答案有帮助吗?
得分 2
7条评论:
Yea be careful I broke mine trying that. Didn't matter as none of the other fixes worked but the battery is soldered in.
完成的
WT14029 takes CR2016 and NOT CR2025, and NOT soldered, and easily replaceable. WT14029 has a screw on the top edge, which is easily accessible without moving any sticker. Which Boogie Board are you referring to?
完成的
You're right! It's CR2016. Thank you for fixing that.
完成的
Also, in trying to replace the battery and even ordering new ones, I figured I would give my boogie board one last chance before the new batteries arrive by replacing it with the SAME old battery. IT WORKED! It just needed a lil recharge?!? My toddlers are very happy!
完成的
I’m using model WT14029 with battery CR 2016 . I can’t get the battery to insert with the screw on top. I can put the battery in without the top and it clears the screen. Is there a trick to inserting the battery with the screw on top?
完成的
显示更多的2条评论
添加一条评论
Pinch the upper left corner but if it doesn't work try all corners
这个答案有帮助吗?
得分 1
添加一条评论
I don't suggest leaving it in one spot for a long time does not work any more
这个答案有帮助吗?
得分 1
1条评论:
Ok thanks worked out well
完成的
添加一条评论
I had similar problem with WT10340. Unused new one opened a couple years later after it was received as a gift. Erase was not working at all from the beginning.
I believe that the major problem is that display terminals are loosing contact from PCB after some time. So you should pinch at the point of that contact. There are also two screws around each of those contacts (they should arrange proper pressure at contacts, however this does not seem to work for longer time...) So the best point to pinch is in the middle betwee each couple of screws.
This solution will probably work for some time until those contacts get loose again. Then you will need to pinch again.
If this does not work for you, remove screws, open the cover from electronics and pinch directly on PCB (through those rubber pads). Optionally check the battery, if the problem is not there.
这个答案有帮助吗?
得分 1
添加一条评论
Worked for me. removed old battery, held clear button for 30 seconds to clear any stored energy if there is any in capacitors.
Placed new battery and it works like a charm again. just make sure you’re using the correct battery model for your device as voltages and amps may very, you don’t want to damage your device by replacing it with the wrong battery!
这个答案有帮助吗?
得分 1
1条评论:
Unfortunately, none of these fixes work on my model WT16312
完成的
添加一条评论
For me, I changed the battery and screen did not clear at first. Then, like with other people, I clicked on button 10 times, but screen still did not clear. I was determined to get it cleared so just decided to just keep clicking and then the screen finally cleared. Must’ve been about 20-40 (I lost count hehe) clicks at different speeds…sometimes I went slow and then I went a little faster and maybe slow again, but I was just clicking in hopes that it would eventually clear, which it did. If that didn’t work, then I was going to press corners or on the battery compartment/area that some had suggested, but I didn’t have to get to that point. Good luck everyone.
这个答案有帮助吗?
得分 1
添加一条评论
Hello, I am a boogie board jot 8.5 owner. The screen was not erasing. I bought a new cr2016 battery. At first, I did not know how to place it. I went on boogieboard.com then user guide and then It showed me how to put the replacement battery. I did not work (The details where not precise enough). Maybe for you it will but for me it didn't. So anyways, it finally worked! but..... It only erased half the screen. I did not remember how I placed it when It erased half the screen so my hopes where gone. I need someone to show me with precise details of how to place the battery for jot 8.5. I need your help! Thank you.
P.S. I hope my little information was helpful
这个答案有帮助吗?
得分 0
1条评论:
I need an answer, and please, MAKE IT FAST. Thank you
完成的
添加一条评论
Well I installed the right battery and all, but it still didn’t work!!! Can anyone help???
这个答案有帮助吗?
得分 0
1条评论:
I got ahokd of company and they sent a new tablet, mine did same thing.
完成的
添加一条评论
It does not work. I tried every posseble way, i just got it too. I hate life. I watched every video. looked at all the answer’s it just does not work!!!!!
这个答案有帮助吗?
得分 0
添加一条评论
I have the answer. I tried everything and still it's a piece of junk Don't fret! I have the boogie board mystery solved!
Remember Boogie Nights? Don't matter, remember DISCO? Ya just like disco, GET RID OF THE STUPID BOOGIE BOARD!
Get a pencil, now get a piece of paper, now get a magnet and stick the paper to the fridge just like we used to do. It never let us down, the pencil broke and resharpening worked like a charm. When the paper was full, guess what, no button!, ya for real dude, no frikin button! So guess what we did... we turned the stupid paper over!
Dumb boogie board is one sided, that's the problem!
Burn your disco records and your boogie boards, problem solved.
Your welcome, now go to freedomopolis(com) and sign up, thanks, I really appreciate it! Kc
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AKPJ50 将永远感激不已
浏览统计数据:
过去 24 小时: 22
过去 7 天: 134
过去 30 天: 737
总计 215,798
