跳转到主内容
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
67 个问题 查看全部
Why does my iPad give sound and music through one earphone?
I just replaced my earphone jack and now only gives sound through one earphone. Please someone help!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
The issue is either your headphone or the jack. Try another headphone and see if that helps. If not, then you'll need to replace the headphone jack. Replacing the headphone jack involves removing the digitizer first. If you haven't done this before, then you should have a repair shop do it for you as it is not easy to do this without breaking the digitizer.
这个答案有帮助吗?
得分 0
评论:
I just replaced the headphone jack so it is new. I dont know what it is.
完成的
添加一条评论
添加你的答案
Slater Guevara 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 40
