Charging Problem iPhone 6
I have an iPhone 6 that has a charging problem: if I replace the battery with a charged one, it works until it becomes discharged, then the battery can not charge again.
It's U2 Tristar charging ic at fault as it refuses to let a flat battery charge.
这个答案有帮助吗?
Thanks, how can i fix it? anywhere i can send to fix it?
Yes. You will need to look for someone that does board level micro soldering for iPhones.
Replace the charging flex cable.
这个答案有帮助吗?
If it charges while not dead, how is it this?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 191
