跳转到主内容
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
LCD Screen won't turn on
My phone was working perfectly fine but then it run out of battery and now the screen won't work, i can hear it receive messages and when i touch the screen it still vibrates as if it's working. When i put it on charge the lcd screen works and says charging... so i know the screen isn't working. PLease help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Try a hard rest to see if that fix's the screen issue if not, try opening the phone and disconnecting the LCD/digitizer flex cable and reconnect to see if that solve the problem.
这个答案有帮助吗?
得分 0
添加一条评论
Hello Natasha Campbell,
It seems to be phone gets stuck or core module gets not respond. as as first step just remove and reinstall the battery. turn on the phone and see whether it's working in order.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Natasha Campbell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 256
