跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1232 个问题 查看全部
问题已关闭
iPhone restart over and over every 5 seconds
my iphone restarts over and over every five seconds and i cant put it on recovery mode or dfu for restore it. then when i finally could put it on dfu,i plug it to itunes and start to restore it but whe the iphone will make its first reboot starts rebooting again and again every 5 seconds
heres a video taken from the iphone https://www.youtube.com/watch?v=NKtdJyaX...
pd: hope you can under stand my cuestion
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sounds like a battery issue, i would reseat the battery connector from inside the phone.
这个答案有帮助吗?
得分 1
1条评论:
I already disconnect the battery and re connect it you think i need to replace it?
and when i start to restore i have 89%
完成的
添加一条评论
You can try the following step:
As the phone begin to reboot, press and continue to hold the + volume button. This process starts the iPhone in "Safe Mode." It may allow you to return to the Lock screen. Perhaps this will assist you in restoring the device in iTunes. I would love to hear how this turned out for you.
Thank you,
Michael
Update (01/04/2016)
Try the following:
1. Disable iCloud syncing
When stuck in iPhone blue screen of death in iwork, one workaround to alleviate the iWork-related reboots is to disable iCloud syncing for Apple's Pages, Keynote, and Number apps.
2. Use the freeware ReiBoot
There is an excellent program called ReiBoot. It is the freeware and you can use it to restart your iPhone in blue screen of death. It will never cause any data loss or damage to your iPhone.
Download and install ReiBoot on your Windows PC (Windows 10/8.1/8/7/XP/Vista). Mac users go to ReiBoot for Mac and it works on Mac OS X 10.11 El Capitan, 10.10 Yosemite, 10.9/10.8/10.7/10.6.
这个答案有帮助吗?
得分 1
1条评论:
no work :( ,I tri it but whatever I do the iPhone stills rebooting until I press home + power for 30 seconds he power off.
the full story it's tis: when te 9.1 be releases I try to upgrade (OTA) but don work something gone wrong an I fall in to a boot loop so I put the phone in recovery mode and I start to restore it then in the first reboot start the problem. the iPhone starts a rebooting again and again every 5 seconds and now finally I pit it on dfu mode but it's te same story in iTunes says waiting for the iPhone and the iPhone starto to looping again
before that happens when I have ios 8.2.1 some times the iPhone bricks and turns completely blue screen (similar at the windows blue dead screen without the white text ) eventually shut down himself and when the ios starts I unlock it and after 5 minutes the iPhone reboots himself again and I could solve that problem restoring and upgrading to ios 9.0.2
hope you could understand my English, this is not my mother language
REALLY THANK YOU GUYS 4 T HELP
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,382
