跳转到主内容
The Toshiba Encore Mini is a 7-inch tablet released in 2014. The device runs Windows 8.1 on an Intel processor. Identified by model WT7-C.
4 个问题 查看全部
wont charge from wall plug or computer help
My Toshiba encore wont charge from wall plug or computer have changed usb cord but still no luck. is it battery or usb port, or an update caused the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
home, this is still a relatively new device and I doubt it is the battery. It is of course possible but I would check the USB port first. Make sure that there are no bend or broken pins. You should consider opening the device and checking the USB port to make sure it is properly connected to the board. Yes, you can change the battery at the same time. Just to make sure you cover all bases.
这个答案有帮助吗?
得分 1
添加一条评论
It's the USB port it's a factory defect
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
home 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 415
