跳转到主内容
佳能数码单反相机的维修和拆卸指南,包括 1987 年首次推出的 EOS 系列。
759 个问题 查看全部
Why does it say "card cannot be accessed"when my camera's on?
Yesterday i went to charge my camera battery. This morning it was fully charged and when i went to put it into the camera and turned it on, it said "card cannot be accessed reinsert/change the card or format card with camera." I tried switching the SD card to all the ones i've used previously, including the one i used the day before. I don't know if there is a problem with my SD port of my camera, or the actual SD cards i have.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It probbably means there is something wrong with The sd port
这个答案有帮助吗?
得分 0
添加一条评论
Hi, if you do not have any important data on you SD card, you can format your SD card to fix the problem. Here are two ways to format the SD card:
Format memory card with Windows File Explorer
Step1: Attach the memory card to your computer/laptop and press WIN logo key + E to go to Windows File Explorer.
Step2: Select “This PC” option from the left side panel and then search for your card from the right pane by seeing the label and drive letter of your card.
Step3: Now, right click on your memory card and select “Format” option.
Format with Disk Management
Step1: Connect your camera’s memory card to your laptop/computer.
Step2: Launch Windows Disk Management and look for your card from the volume list, then right-click on your card to open a context menu.
Step3: Select the option to “Format..” and then follow the steps as directed to complete the process of formatting.
While if you have data om the card, remember to make backup in advance.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
emilylee2011 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,056
