跳转到主内容
第三代 Surface Pro 平板,发布于2014.6.20
121 个问题 查看全部
Damaged screen. How do I know which screen version to order?
The title.
damaged screen. the lcd itself look just fine, no dead pixels. but the touch has gone. i saw that lately there's options to buy screens even v1.1, but how do i spot which version i have?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Most Tablets have a serial number on the rear cover. Model number as well, When ever you buy a communicating device check the settings and on "my device" section it should tell you all the numbers for a particular device, Model, serial, other info. hope it helps. If you can get the Digitize'r out it should have a number on the Flat cable, or on the ribbon cable. LJ.
这个答案有帮助吗?
得分 0
3条评论:
Thanks for the answer. to be honest, i don't understand your answer. I know where to find the serial number. But how do i use him to get the digitizer version? I don't want to open the device screen until the screen will arrive. it's too risky, this is very gentle device. tried to look at the computer specs in speccy, didn't find any useful information. someone?
完成的
need to remove the digitizer? seems that all physical things that is produced has to have a number of some kind on it? pasted, stamped, somewhere on it?. to ID that part. I took a break.
完成的
This reply is not helpful. What is a communicating device?
完成的
添加一条评论
添加你的答案
dtamish 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,243
