跳转到主内容
15.6" Windows 7 laptop with AMD E-300 processor.
4 个问题 查看全部
问题已关闭
Window filckering and unexpected internet crashes!
For some reason, any windows that are open will flicker uncontrollably; and whenever I try to open up the internet, it will suddenly crash without warning. I have tried opening the internet with different browsers, but they had the same outcome while still being connected to the internet.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
1. Try connecting an external monitor and see how it behaves. See the following link.
http://www.mytoshiba.com.au/support/item...
If you have no spare monitor go to item 2.
If you have no problems there may be something wrong with your screen.
If you still have problems there may be something wrong with your graphics adapter.
2. If you click on Toshiba Assist icon, you should hopefully find a program called PC Diagnostics.
To quote the "blurb":
''Toshiba PC Diagnostic Tool provides you with a user-friendly application that can be used for analyzing the system configuration and obtaining detailed information on each of the connected hardware components.
However, its functionality is not limited to displaying the description of each piece of hardware. The application can also be used for diagnosing devices that have problems working properly and running benchmark tests meant to assess their performance.''
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 80
