The temperature gauge reaches 4 and switch engine off
I have a clio diesel 1.5 once the temperature gauge reaches 4 and switch engine off it takes about 20 seconds bk on the Dynastic test come up with a load of weird codes
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论:
So sounds like your Clio is overheating. What year is it? What have you checked? what exact codes are you getting?
完成的
04 plate we had a diagnostic check and they just kept sayin there nothin wrong don't no what code they used ! Thanks
完成的
Haven't got code to hand at mo sorry the garage said he's never seen theses codes b4 took it 4 a test drive and done test again cum bk clear
完成的
Is it just the gauge that goes up or is your Renault truly overheating?
完成的
Gauge ! But don't understand why after a long journey we switch the engine off back on takes about 20 seconds thanks appreciate your help
完成的
添加一条评论
