跳转到主内容
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 个问题 查看全部
问题已关闭
Replaced Digitizer and LCD. LCD not working
broken digitizer. LCD working. Replaced digitizer. LCD not working. noticed that i damaged ribbon cable connection. Ordered and replaced LCD. LCD still not working. IPAD is on. Is detected by find my iphone and plays sound. have tried hard reset. Successfully shut down (not seen by find my iPhone). turned back on (seen again by find my iPhone). Next suggestion.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you didn't power off the iPad when working on it , it is likely that you blew the lcd backlight filters when you plugged or unplugged the lcd. This will require a board level repair.
这个答案有帮助吗?
得分 1
3条评论:
"board level repair"?
i presume it means i ruined the mother board
完成的
Thank you for your answer, by the way!!
完成的
I wouldn't say ruined, but it will need some micro soldering.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 83
