How can I fix the headphone port of a kindle fire hd6?
My son's headphones broke inside of the jack. Now there is a broken piece of the headphone stuck inside. Please help, how can I get it out?
I would suggest you bend a paperclip in a tight "U" shape and put a drop of crazyglue on it (shape to improve traction) then insert the paperclip into the port and let it set for 15min. The broken part should have enough surface damage that it will stick and then you can pull it out. Hope it helps, did it with an iPhone 4 but not sure if the jack port is tighter in a kindle.
Good luck!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 252
