跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
293 个问题 查看全部
How do I reassemble the thermal sensor again?
In the HDD replacement guide, you state, "During reassembly, be sure that the thermal sensor connector is connected to set of pins closest to the SATA connectors."
Does that mean connect it as you did when you uninstalled it, or to assemble it another way by flipping the connector?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Put it back the way it originally was.
这个答案有帮助吗?
得分 2
3条评论:
I found what your talking about but I don't get what the problem is. My fan noise is still like a jet. I know what normal fan noise sounds like, but this thing is on full blast after about 15 mins of web browsing. I checked the thermal senor wire to the HDD and all was connected correctly, the way it was before I opened it. I worked very carefully and followed the guides exactly.
I am getting frustrated being this is the second iMac in 4 days. Both doing the same thing after upgrading the drive. The tech support from OWC said that the HDD was compatible and the fan noise was due to incorrect sensor connection. After double checking, I am all out of options.
完成的
There are three different part numbers for this sensor cable:
922-9215 Hitachi
922-9216 Seagate
922-9217 Western Digital
I've never seen anything like this. What brand of drive did you get?
完成的
Hook it back up the way it was before teardown. +
完成的
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,304
