跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
297 个问题 查看全部
HDD replaced but fan is contiuosly running and very loudly?
I just purchased a new Intel i3 mac and then bought a HDD upgrade to a 1.5TB Seagate as recommended by OWC.
After following the guide found on here, I was able to successful install the drive and get the machine back up and running.
However after about 5-10 mins of use, whether just on idle or browsing the web, my CPU fan blows loudly and continuously without stopping.
I downloaded istats and it shows my fan consistently blowing at 1199 rpm. With the noise increasing, the fan still stays at those speeds. I returned the iMac and exchanged for another. Once installed the new HDD, I still had the same issue. Looks like an install error, but I followed the guide found on here to the T.
The tech guy at OWC said it could be the thermal sensor, not placed correctly, etc. When connecting the thermal sensor, I connected it the exact same way when I disconnected it. Maybe this is where I went wrong. The guide states, During reassembly, be sure that the thermal sensor connector is connected to set of pins closest to the SATA connectors. What does that mean? I didn't understand that, should I have flipped the connection as oppose to connecting it the exact same way as when I removed it?
I was wondering if anybody could confirm this. Thanks in advance.
This is the drive I bought
[关联产品丢失或禁用: IF107-088-1]
Seagate one. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
As far as i know the thermal sensor is inside the HDD on these models. You must install a drive from the same manufaturer and same series to get the sensor to read correctly.
这个答案有帮助吗?
得分 1
4条评论:
Yes, I did install the correct drive. I made sure that I purchased the same manufacturer. The original 500GB drive was also seagate. I added the line, after looking at the guide again. Maybe I installed the thermal sensor incorrectly. Could you help me understand what it means by, "During reassembly, be sure that the thermal sensor connector is connected to set of pins closest to the SATA connectors."?
I installed it the same way as I removed it, but maybe this is the problem.
完成的
The board should be labelled what connector fits where. It's very small writing, have a look.
完成的
I found what your talking about but I don't get what the problem is. My fan noise is still like a jet. I know what normal fan noise sounds like, but this thing is on full blast after about 15 mins of web browsing. I checked the thermal senor wire to the HDD and all was connected correctly, the way it was before I opened it. I worked very carefully and followed the guides exactly.
I am getting frustrated being this is the second iMac in 4 days. Both doing the same thing after upgrading the drive. The tech support from OWC said that the HDD was compatible and the fan noise was due to incorrect sensor connection. I am all out of options.
[[IMG]http://i981.photobucket.com/albums/ae298...[/IMG]]
完成的
Hi, I have happen this problem same as you when I changed HDD with Seagate 1TB, the fan run sound like a jet after 10min when boot. how to fix it?
Franky
frankyching@yahoo.com
完成的
添加一条评论
i have resolve the problem check this post.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,156
