跳转到主内容
加入维修社区 - 创建账户
The third iteration of the 10.1 inch Galaxy Tab tablet.
WiFi Connects and drops at random
My WiFi on the Samsung Galaxy tab 3 10.1 GTP5210 will sometimes connect to a network (if at all) and then drop connectivity after a few moments. I've performed a hard reset, a factory reset, tried multiple networks. I am wondering if this might be a physical component I can replace for a WiFi antenna and if so any recommendations on doing so. My next step is to try a firmware update but I am not hopeful.
Got the tablet for free from work because of the issue so I am trying some cheaper options to fix before giving up on it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
This is free, go to google play store, go to apps, key word "wifi analizer" select the one by farcpro. Wifi must be runing to work the app. This app tells what chanel you are on, who is on your hot spot chanel and more. I have it on all of my devices as ive been in your dark spot. I hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
Same issue here. Any solutions?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 51
总计 4,625
