跳转到主内容
修复你的物品
维修的权力
商店
Why is my phone not turning on?
I recently got a new battery for my phone because the previous one was malfunctioning. I also was using a USB charger for my phone which was plugged to my laptop. After sometime of using the charger to charge, my phone's screen would become a different colour and as well freeze, so all i would do was simply unplug the charger press the power button to but the phone on sleep mode and replug the charger and continue using the phone. Now last night I went to a party and came home to find my phone's battery life to be dead. So i did my normal practice of plugging the charger to my laptop and charge the phone. Before I closed my eyes to sleep I saw the battery and the little green line to the bottom signalling that the phone is charging. When I awoke this morning to turn on my phone, my phone did not. After using a wall unit and placing the charger in the wall unit to see if it would have started the phone the same reaction occurred. The phone refused to urn on even after using different usb chargers and wall units. I even took out the battery and placed it back in and the same reaction. So my question is why is my phone not turning on? CAN SOMEONE PLEASE HELP!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
Sounds like the battery took a sh!t, it never hurts to order a new battery online either on EBay or Amazon for your phone. Make sure you find a OEM battery. Also i recommend always charging your phone via the wall not the computer. A wall charger generates more charge power, i would hard reset it following these steps and then plug it into the wall and let it charge, if same problem occurs then you need a new battery or at least a used one that has been tested
http://www.hardreset.info/devices/samsun...
这个答案有帮助吗?
得分 0
评论:
Wipe cache then reboot
完成的
添加一条评论
添加你的答案
john henderson 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 94
