跳转到主内容
Model A1285 / 8 or 16 GB capacity
206 个问题 查看全部
My headphones are not getting sound, what's wrong?
My head phones are not recieving sound from the i-pod. I've double checked the headphones and they work. that means it is the i-pod, but what part exactly? How can it be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Often on Ipods the Phono Jacks can stop working if there is dirt in them, for this i would suggest a cotton bud / tooth pick or something simmilar.
Otherwise the Jack has come loose from its solder and will need to be replaced. ( Parts available on ebay etc ) but if you have no soldering experience, i would leave it to the professionals.
这个答案有帮助吗?
得分 0
添加一条评论
I've come across this as well. For a temporary fix you can take a small piece of tin foil and wrap your headphone jack with it. Not too much though as the fit is tight. What this does is it removes the clearance created by the wearing out of the contacts in the jack and allows a complete contact to be made. Now be ware as well that when you remove your headphones, the tinfoil will probably stay in the jack, making it so that the speakers will not work because it thinks the headphones are still in. You will have to fish out the tinfoil if you want sound without using the headphones. I found that a wooden scewer ( for souvlaki) works well, or a small tweezer. You will need to replace the jack for a proper and complete fix though. Good luck;)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dylan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 2,472
