跳转到主内容
Model A1138 / 1440x960 screen resolution
85 个问题 查看全部
Loss of wifi range
Hello, I have one of the last PB G4 15' 1,67Ghz, and since a few weeks my laptop WIFI do not work well:
if i am near my Router everythings works fine, but when I am far from the router, I do not see the WIFI anymore.
Any other laptop or Iphone still reach the wifi so it is not linked to the router itself.
I have checked inside the laptop the airport connexion with its antenna an it seems to be OK.
Any suggestion to solve this problem?
Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
If the connections are good and the router is good that leaves the Airport card. Do you have another you can try in your computer? Ralph
这个答案有帮助吗?
得分 1
添加一条评论
You mention "since a few weeks"...did this computer work fine on the router previous to a few weeks ago? If so, can you think of anything that may have happened to the machine around that time, or possibly did you install any network-related software, a VPN, etc.? You could always wipe the system and reload the OS in order to rule out software as being the issue. A friend had a similar problem, and it went away when he wiped the system and went to Snow Leopard. Obviously Snow Leopard will not work on this laptop, but my point is that a fresh install may help. And of course make sure it is fully patched, because very early revisions of any Mac OS tend to have networking and especially wireless glitches.
这个答案有帮助吗?
得分 1
添加一条评论
Thank you for these answers.
The whole installation was working since 2 years, and I have made no change at all.
Since the problem has appeared, I'have tried to re install Mac OSX Leopard, and made all the sw update but no change: the wifi range is still poor.
- for me it is not a software issue.
What is strange is that when I am near the router the WIFI works just fine.
I have a professionnal PC, and it still works from everywhere in the house, and it is the same with my iphone in WIFI.
Can it be a problem with the wifi antenna which seems linked to the screen?
Is there a way to put a third party pcmcia WIFI card?
这个答案有帮助吗?
得分 1
1条评论:
Yes the computer has a pcmia card slot. Ralph
完成的
添加一条评论
添加你的答案
Regis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,012
