跳转到主内容
Second iteration of Ematic's line of Genesis tablets. It was released in December 2012 and is powered by Android 4.0 Ice Cream Sandwich.
Why won't my tablet connect to WiFi?
Why will my Ematic Genesis 2 tablet not connect to the WiFi?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
hello, try to remove security from your network then log in (you should connect) and whether or not has any update available for your android ver. .Also, try changing the authentication method
完成的
添加一条评论
1个答案
Check to see if WiFi is turned on? And also if the router is connected and functional.
这个答案有帮助吗?
得分 0
1条评论:
I try to turn WiFi on - it resists, then says, "turning wifi on" - never changes after that. Router is good.
完成的
添加一条评论
添加你的答案
Brandon Key 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 894
