跳转到主内容
The Asus MeMO Pad 7 ME170C is a touch screen tablet manufactured by Microsoft and released in August of 2014. It has a screen resolution of 1280 x 800. Identified by model number K017.
10 个问题 查看全部
Why won't my Memo Pad turn on?
My Memo Pad won't turn on .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
It is not turning on because it's mother board is basically f****d ok and it won't reboot take it from the 1 who had there's take to be repaired by currys PC world
From
Liamward311@gmail.com
这个答案有帮助吗?
得分 0
添加一条评论
Try to reset it by pushing power key and volume at same time for 10 sec then put it on charger repeat if don't power up within 5 min. If it don't come back on after 3 or 4 times with this method I would maybe check the battery then the charging port last option would be your motherboard.the parts for these tabs are cheap compared to other tabs, it's the labor that costs. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
There is a small hole on the side of it that will reset it for you if you hold it in. You will need something small to do it tho. It took me the longest for me to figure this out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tatiana Schneider 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,685
