跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
573 个问题 查看全部
iPad Air Shadow/ waves left side
Hello,
i have an iPad Air 1 Gen LTE 16GB.
I bought it on eBay with an cracked digitizer and LCD.
After replacement there are some shadows/ waves on the left side.
What is this?
The old cracked screen had this also before..
It works pretty well with iTunes no other problems but it look´s horrible..
Does anyone know how to fix this?
Thank you so much for your help! I love this Community!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
So this is appearing on the new lcd that you installed?
完成的
Thank you so much for your answer.
SMD Soldering should be possible but i need the new parts.. and how can i identify the dead filters on the mainboard?
完成的
yes on both..
完成的
添加一条评论
1个答案
最有帮助的答案
Looks like a backlight issue. If it is appearing on both the old and new LCD then it must be an issue on the logic board (backlight filter perhaps) which will require board level repair.
这个答案有帮助吗?
得分 1
2条评论:
Thank you so much for your answer. SMD Soldering should be possible but i need the new parts.. and how can i identify the dead filters on the mainboard?
完成的
Any suggestions if it's only happening on the left side?
完成的
添加一条评论
添加你的答案
Christian Wolfram 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 1,363
