跳转到主内容
The Alcatel One Touch Idol 2 features a 5" qHD IPS-LCD display along with a 1.3 GHz quad-core processor. It was released in February 2014.
36 个问题 查看全部
Can anyone help me with the microphone?
I was replacing the display and when i turned my phone on and got the first call i realized that the microphone doesn't work properly. The other person can hear me but with a buzzing and i literally need to yell .
I don't have any idea where the mic is located, but i checked all the parts five times and everything seems is in their place.
You'll do me a lot of help if you tell me where is the location of the MIC and what could i possibly do...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
Settings on your phone - network , restart the phone, you can replace the SIM card and replace the local test. The fault persists , then open the phone priority , select the network mode to use only 2G networks to test recommend that you re- install the SIM card.
Or else when installed microphones in the connection port that is not connected , you can reconnect it.
这个答案有帮助吗?
得分 0
1条评论:
I don't see how the SIM card can bee the problem for the microphone bad behavior... The 2g theory is a better way to start but i already know that other people heard me clearly with a 3g network. The problem came after I opened my phone to change the display so i know that is a hardware problem but i don't know how to fix is if it is fixable... Anyway , thanks for the good intention about helping me, if you think you know anything else that i can try or you have the knowledge of where is my phones microphone please answer back :D
完成的
添加一条评论
Microphone is located in bottom just left of circle on bottom.
这个答案有帮助吗?
得分 0
添加一条评论
The problem is from the new screen because I noticed that not all new screen mouth piece connection works but a resistor can help solve the problem, all you have to do is to connect one of the month piece leg to ear piece port and the black colour leg to any null I. C in the panel.
By http://fb.com/mkoonlinemobile
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hristijan Stojcevski 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 15
总计 14,261
